1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#881036 09/08/2012 9:55 AM
Can this be used on bulb sockets in our old trucks? Should it be?
Sure
It does not promote electrical conduction, it acts as a seal and helps to stop oxidation/corrosion (making a moisture/oxygen barrier) outside of the contact surface (which you want to be clean metal to clean metal). It is electrically non-conductive.
http://en.wikipedia.org/wiki/Silicone_grease
http://www.wisegeek.com/what-is-dielectric-grease.htm
I use dielectric grease on every electrical connection I ever do. As Tim mentioned, it helps prevent corrosion.
Jeff
My 1953 Chevrolet
1947.1 Gallery
I have been using the gm nyogel 760g, or the motorcraft electrical grease which I believe is xg12. For small terminals, fretting is causing issues, and these greases prevent voltage drops on low current circuit connections. I have fixed many vehicles with various electrical issues with this stuff.
Hello,
Here is a ancient Chinese secret.
"NO-OX-ID A-Special Electrical Grade" is the best bar none. 1 tube will last a lifetime, Unless you let your neighbor use it, than it disappears.
The telephone company has been using NO-OX-ID for seventy years. I have seen fifty-year-old NO-OX-ID on connectors that I've disassembled and the stuff is still goopy and the connections are still bright and shiny as the day they were made. http://www.sanchem.com/aSpecialE.html
Don't waste your time with anything else.
Cool - I thought I was the only one who uses that stuff - love it. And you're right, I've had 1 tube for over 10 years now!
Does it work as well on battery terminals as they say it does?
That alone would be enough incentive to buy it.
Larry
I don't own a vehicle that isn't old enough to drink.
jorb's product should work fine on battery posts.
I have used for years the following, readily-available product:
Description of NAPA product:
(Conductive) Anti-Seize Compound & Lubricant, 4 oz
NAPA Part: BK 7652569
Product Line: Balkamp
Features_&_Benefits:
Premium Quality Copper Anti-Seize & Thread Lubricant That May Be Used to Prevent Seizing, Corrosion & Galling Where High Temperature Conditions Exist, Contains High Percentage Of Micro-Fine Copper Flakes, Provides Good Electrical Conductivity
I also use the battey post anti-corrosion felt rings available everywhere that auto parts are sold.
Larry
Telephone Central Office Switching equipment operate on (-48 volts DC (meaning the Hot side is negative) from banks of batteries connected together using big fat cables coated with NO-OX-ID. The batteries are stored in a separate room from the Switching equipment. The Switching equipment get their power directly from the batteries. The batteries are charged from rectifiers that run on outside AC power from the local utility. The rectifiers convert 220 AC power to -48 volts DC to charge the batteries. The back-up power source to charge the batteries are diesel generators. When they loose outside AC power the diesel generators automatically start up and charge the batteries. They have about 4 hours of diesel fuel, the batteries then are on there own, and last about 4 hours, then phones go DEAD.
After reading the above, do you think NO-OX-ID would work on batteries?
jorb, I'm sorry it's still a guess. I'm not questioning that it an excellent product for electronics. I was hoping to get some practical experience with automotive batteries in an old truck. I should have been clearer on what I was looking for.
Larry
jorb, I'm sorry I was hoping to get some practical experience with automotive batteries in an old truck.
Larry
No need to be sorry Larry,
I was just into one my funks.
I'm sorry, I should have been more respectful.
NO-OX-ID will work on any electrical connection old or new.
NO-OX-ID prevents the sulfuric acid and hydrogen crystals forming, that's the white powdery corrosive substance and maintains a solid metal to metal bonded connection.
This stuff works great on scratchy volume controls. DeoxIT, #D5S-6 http://store.caig.com/s.nl/it.A/id.1602/.f?sc=2&category=188
Thanks, I hope the info helps.
[quote=jorb
[/quote]
That's what I was wondering about. Most of the products you find at the parts houses seem to create as big a mess as they are suppose to prevent. Something that would coat the battery terminals with out a mess would be nice. In the next few months I'm going to replace the batteries in my motorhome. I'll have to give a NO-OX-ID a try.
Larry
I've been putting it on my daily drivers battery terminals for years as well. Great stuff.
