0 members (), 118 guests, and 1 robot.
Topics128,113
Posts1,056,619
Members48,450
#881075 09/08/2012 3:24 PM
Not sure if this is in the right place but the gas tank is inside the cab so I guess that qualifies as 'Interior'.
I was fitting my new 12v gas sender today and the screws supplied are the wrong diameter.
Can anyone tell me what I'm looking for,sadly i'm a victim of the European metric system and don't understand those funny old fashioned sizes...... wink
More pix on Flickr.
What tank are you using?
If I remember correctly the screws on my original tank were smaller than the ones on the new spectra tank I purchased.
Fortunately the new tank came with a set of screws for the sender. ...click...
I'm out of town right now otherwise I would measure both for you
jockbolter50, 10 X 32 X 1/2" are the size I used... I also went with allen head screws in that size...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
machine screws on most everything will be 6-32 or 8-32, find a handful of each size in different lengths just to have handy wink
The tank is a Counterpart item,I had two screws left over from the adjustable sender that fit,unfortunately I don't know what size they are either....
That confirms the answer I received from one of my AD Trucker pals on the HAMB.
Thanks!
Bill... it's hard enough to even find Imperial stuff here,never mind handfulls!
The one source I have here tears me a new one every time I go into the place.
They charged me nearly $10 for 4 stainless screws for the windshield centre bar..... big_eek
More pix on Flickr.
Ex Hall Monitor
Ex Hall Monitor
...it's hard enough to even find Imperial stuff here,never mind handfulls!
Tell me the size you need and give me your mailing address. I'll send you a care package.
Thanks for the kind offer Tiny,ironically you could have probably still sent me them cheaper than that guy would have charged me here.
Long story short,I got to thinking and simply re-tapped the screw holes to 5mm metric.
I used plenty of grease on the tap to avoid swarf dropping into the tank.
Job's a good 'un! thumbs_up
More pix on Flickr.
Moderated by  ndkid275, Phak1
