3 members (52Carl, Hotrod Lincoln, moparguy), 378 guests, and 4 robots.
Topics128,159
Posts1,057,033
Members48,460
i removed all of the rotten insulation and rat nest and cleaned the top of the inside of the cab. any suggestions or different ideas to treat and reinsulate the cab about the headliner, i thought about treating it with por15. i have a roll of industrial insulation that is 3/8" thick with a backing that looks like vinyl top materail on the other side and also thought about cementing it in, also what kind of insulation and cement would you recommend.thanks
1953 Chevy 3/4-Ton Stakebed
[url=http://fiftythree-chevy-flatbed.tripod.com/
Originally Posted by DADS50
I used this stuff
here is a pic
used it on the firewall also
POR would be a good idea, and the insulation you have sounds fine, similar to the stuff DADS used, or the foil faced bubble stuff a lot of folks use .... most any of them will stick well with contact cement
Moderated by  ndkid275, Phak1
