1 members (1955 1 Series),
64
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | i removed all of the rotten insulation and rat nest and cleaned the top of the inside of the cab. any suggestions or different ideas to treat and reinsulate the cab about the headliner, i thought about treating it with por15. i have a roll of industrial insulation that is 3/8" thick with a backing that looks like vinyl top materail on the other side and also thought about cementing it in, also what kind of insulation and cement would you recommend.thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | POR would be a good idea, and the insulation you have sounds fine, similar to the stuff DADS used, or the foil faced bubble stuff a lot of folks use .... most any of them will stick well with contact cement
Bill | | |
