1 members (jmoore), 124 guests, and 2 robots.
Topics128,093
Posts1,056,478
Members48,444
Greetings,
I have a Harrison (11 55) deluxe heater that I am getting ready to install. Does anyone have an assembly/installation manual for this heater? I am pretty sure I have all the parts assembled correctly, but am unsure of the connection between the two main assemblies.
I am pretty sure which holes it goes through in the firewall (I have lots to choose from, thanks to prior owners and their active hole saws), but want to get the cables right and the wiring done correctly. Here are a couple of pics of the heater I have:
http://i1195.photobucket.com/albums/aa397/fourbrads/57%20chevy/DSC03450.jpg
http://i1195.photobucket.com/albums/aa397/fourbrads/57%20chevy/DSC03618.jpg
http://i1195.photobucket.com/albums/aa397/fourbrads/57%20chevy/DSC03615.jpg
http://i1195.photobucket.com/albums/aa397/fourbrads/57%20chevy/DSC03454.jpg
Any help is greatly appreciated.
Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
Jim - the whole install is shown in the Accessories Installation Manual .... you can find some pics here of the heaters - the firewalls had the locations marked for tubes of the 2 different model heaters, and the dash mat should have "knock outs" in those locations if you still have the original, the heater sets it's own location because of the piece that attaches to the kick panel opening, start from there .... the cables and wires really can only go where their length allows, pretty straight forward .... also, there are some "stand offs" not shown in your pics that go on the mounting studs to level the unit to the firewall and line it up to that kick panel opening, short pieces of 1/2 copper plumping pipe work
Thanks Red58,
Was hoping someone had a copy of the manual pages I need, but it won't hurt me to spring for the whole book. Suspect I will need it in the long run.
I assumed I'd end up needing the spacers at some point (which I don't have), but don't know how long they are. Will the manual have that do you think?
Also, in the TF Heaters pic, is it the wide rubber band that holds the two ends of the subassemblies together? Together with the proper mounting procedure? Pretty sure they have the same output width and height.
Appreciate your time,
Jim
235, 3-speed w/OD
the rubber sleeve just closes the joint, the 2 sections mount individually ... the book doesn't have dimensions, but I'll look at the one here and get the length today for you, there's one longer ... and OK, for instant gratification I put up the pictures from the book, 3 start here wink
OK, the spacers are 9/16 except the one on the long stud, which is 1 & 3/16
Well now, that is just OUTstanding! Thanks very much. I hate to admit that I love the instant gratification...but there it is...
To assuage my guilt, though, I will get the book.
And, I appreciate you getting me the spacer sizes too. Owe you one!
Thanks again, Bill.
Jim
235, 3-speed w/OD
Moderated by  ndkid275, Phak1
