| | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Anyone know if you can fit a 12 valve cummins in my 1955.2 GMC 350? Also I want to install newer better axles, any ideas? | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Anyone know if the 55.2 GMC 350 front axle is similar to the big AD trucks?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Check kingpin dimensions, should be easy to look up in your shop manual. The 2 ton AD trucks have a 1.109" diameter kingpin.
Grigg | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Hmmm I need to get one of those. | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Hey Grigg... Tell me about your Detroit 4-53T.. I'm curious  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | That pretty much covers my swap.
About swapping a 4-53T into an AD truck, I think it's as big as I'd ever want to do, it fits but sure is tight. A 3-53T would be a much simpler swap, and one I have planned for my 52 1 ton pickup.
Grigg | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | I watched those videos. Took me by surprise on what jumped out of the trees! I couldn't help but chuckle a little bit! That's pretty cool I must say. I don't know much about diesels, thats why the questions. what do the Detroits come out of? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | One came out of a 1978 GMC 6500, the one I replaced it with was new in 1985, still new surplus likely intended for stationary equipment.
Grigg | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | So is it a 4 cylinder? What's your HP and torque? Mpg? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The newest Silver 4-53T puts out 185 HP at 2500 rpm and 435 ft lb at 1,500 RPM. don't have a real MPG figure yet, with a 7,000-8,000 lb truck I'd hope to see 15-18 mpg.
Grigg | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Hey Grigg --- sounds mighty interesting. Had an old 6V53 (supercharged) in a Blue Bird...is the "T" designation for "Turbo" by any chance? Any pix of that motor?
Also, while I'm not familiar with the Detroits, I do know that modding a stationary engine to over-the-road use can be very tricky with any of the Cummins line. The are set up very differently. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Try the "Click here for all pictures" link in my signature. Yep, the T is for Turbo. I had a 6V53 with twin turbos in a 61 F350, that was quite a truck!
Making a stationary Detroit into a vehicle engine is a quite simple, just change the governor to a limiting speed type if it's not already. Likely you will change oil pickup and sump but not always necessary, and find a flywheel for an automotive clutch.
Detroits are quite simple and easy to work on, and the service manual is very well done.
Grigg | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Hey Grigg, is there other trucks other than the p-30 that have the 1.109 kingpin with disk brakes that will work? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Im condused... the P30 has larger than 1.109" kingpins. Nothing I know of has 1.109" kingpins and disc brakes.
What are you trying to do? Did you checkout the disc brake sticky? | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | I looked and i thought i read that if you had the 1.109 kingpin that there are disk brakes you can bolt on . | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sort of, still takes some work. The P30 shares brake parts with the 3500HD. Check out the sticky disc brake thread again as it has what I know about them. | | |
