| | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys, I have an auxiliary transmission in my newly aquired 1946 Chev 2 ton cabover. There is no ID. plate on it, it has two shift rods on it that are passing through the main housing not in the cover. I'm assuming it is a three speed, but I'm not sure, I've looked in my old books, but most show a trans. with the shift rods in the cover. Anyone have any idea what this trans might be??? Thanks | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Some pictures might help. There were several brands of auxixilaries, with the most common being Spicer and Brown-Lipe. I think there was also a brand called "Truxtell" or something similar, but they mainly made auxiliary drive axles for the Model T and other older commercial vehicles. Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Watson is another brand.
Some pictures would great | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Most ones in like trucks are fine for gassers, not so good for 6BT, etc.
