| | | Forums66 Topics128,050 Posts1,055,760 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 64 | Have a question on my 228, please keep in mind I am not an engine guy and will probably call something by it's wrong name. When I take the valve cover off there is a tube that sits on the last post I call that the oil return tube. I believe it takes the oil fron the shaft and drops it down into the lifters[if it was not crimped] On mine the end is crimped closed, some oil flows thur but not much, should it be? The tube does have a pinhole break in it which is probably metal fatigue? I currently have oil pressure which runs from a low of 20 to a max of 50, Is this all right? The engine has not been rebuilt The end of this tube being crimped bothers me because I worry it is restricting the flow of the oil but also realize that it may need to be crimped to allow the rocker arms to get lubricated> Am I making nothing into something ? Thanks for response, Doug . If I need a new oil return tube anyone know were I can get one? | | | | | Joined: Jun 2003 Posts: 4 New Guy | | New Guy Joined: Jun 2003 Posts: 4 | Doug, You might ask this question to the old GMC trucks forum, oldgmctrucks.com There are a lot of helpful members there that have a wealth of information about these GMC engines. I think the overflo tube goes on the number 4 rocker arm support. The oil from that tube flows down almost on top of the distributor gear. I dont think it should be crimped. Your oil pressure is probably ok for a engine with some wear. | | |
