Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (mo2cyl, Rusty Heaps), 59 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#879110 08/30/2012 6:57 PM
Should I just use POR-15 inside a cab corner that I now have access to, or would I want to do some other treatment to it. I'm afraid to use naval jelly and not being able to get it out of the overlapping seams,thanks.
pictures below
https://picasaweb.google.com/111413431667404132006
Jim D - '48 GMC 1ton pickup
are you talking about the area above
your patch
and on up into the cab?
I understand that to be prime por application surface since it needs something to 'encapsulate' where as your nice patch area may not hold it that well.
nice albums
Give me ambiguity
or give me something else
CASO #879137 08/30/2012 9:10 PM
Yes on both sides of that metal patch. Just brush on the por? After I use marine clean and metal ready? Or do I not want to use those two and risk not being able to wash out the metal seams, thanks
pictures below
scratch the new stuff up with some rougher sand paper to give the
por a tooth to stick to
I do plan on using por-15 on the underside of the floor and inside the corner. I'm just worried about the seams all over the truck and not being able to wash away the residue before I por-15 it. It looks to me like the marine clean and metal ready prep stuff is a lot thinner than the por-15 and I wonder if it will penetrate and therefor protect all the way into the seams?thanks
pictures below
I will sand the new metal
pictures below
