| | | Forums66 Topics128,090 Posts1,056,018 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 32 | Should I just use POR-15 inside a cab corner that I now have access to, or would I want to do some other treatment to it. I'm afraid to use naval jelly and not being able to get it out of the overlapping seams,thanks. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | are you talking about the area above your patch and on up into the cab? I understand that to be prime por application surface since it needs something to 'encapsulate' where as your nice patch area may not hold it that well. nice albums
| | | | | Joined: Oct 2010 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 32 | Yes on both sides of that metal patch. Just brush on the por? After I use marine clean and metal ready? Or do I not want to use those two and risk not being able to wash out the metal seams, thanks | | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | scratch the new stuff up with some rougher sand paper to give the por a tooth to stick to | | | | | Joined: Oct 2010 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 32 | I do plan on using por-15 on the underside of the floor and inside the corner. I'm just worried about the seams all over the truck and not being able to wash away the residue before I por-15 it. It looks to me like the marine clean and metal ready prep stuff is a lot thinner than the por-15 and I wonder if it will penetrate and therefor protect all the way into the seams?thanks | | | | | Joined: Oct 2010 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 32 | I will sand the new metal | | |
