| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 18 New Guy | | New Guy Joined: Nov 2011 Posts: 18 | My 49 one ton pick-up has mildly loose steering. i've replaced the tie rod and ends, new king pins, had the front end aligned, adjusted the steering. I was wondering... has anyone put a steering stabilizer on their truck and did it help? I guess it's the little bump steer is what I find most frustrating. Thanks, Mike | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Are you driving on bias ply tires? People who have never driven on anything but radials will find bias ply tires feel 'funny'. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Has the ride height been changed from original? If the drag link from the steering gear to the left front wheel isn't parallel to the ground, there's nothing that can be adjusted to eliminate bump steer. A stabilizer won't help much in that situation. It's a geometry problem that will only get worse as the angle of the drag link off horizontal increases. Jerry
