2 members (WICruiser, tclederman), 41 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#878792 08/29/2012 1:35 PM
My 49 one ton pick-up has mildly loose steering. i've replaced the tie rod and ends, new king pins, had the front end aligned, adjusted the steering. I was wondering... has anyone put a steering stabilizer on their truck and did it help? I guess it's the little bump steer is what I find most frustrating.
Thanks, Mike
Are you driving on bias ply tires? People who have never driven on anything but radials will find bias ply tires feel 'funny'.
Has the ride height been changed from original? If the drag link from the steering gear to the left front wheel isn't parallel to the ground, there's nothing that can be adjusted to eliminate bump steer. A stabilizer won't help much in that situation. It's a geometry problem that will only get worse as the angle of the drag link off horizontal increases.
