| | | Forums66 Topics128,185 Posts1,057,200 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | Found a 38 car 216 motor and am gonna put it into a 49 panel truck. Figured I would have to change the front motor mount but in lookin at it, there are 2 square holes in the mount plate that align perfectly for the motor mount on the panel frame. Am I imagining that this is right that back then u could put the motor ina truck or car without changing the front mount plate? My later 216's will not swap car to truck without changing the front mount plate on the motor. Any help, thanks, Eric | | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | If it has the holes in the right places on the front plate, then it should work.
Professional Novice
| | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | Shoot if this works after I switch the bellhousing, I may just drill the next one the same way if I ever need to put a car motor in a truck. Thanks | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Shoot if this works after I switch the bellhousing, I may just drill the next one the same way if I ever need to put a car motor in a truck. Thanks That's the way it is commonly done. | | |
