1 members (LAROKE), 127 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,471
Hi all,
Finally starting to work on my Chevy 3800 duallie. I want to know if I can run the duallie hubs on the rear eaton ho72 with newer single rim wheels or will it cause issues with wear on the axle shafts and bushings?
I recently purchased my motor-- a mercedes om617.951 5 cylinder turbo diesel. Getting excited to make progress.
So you have a rear axle that came with dual wheels on it?
You want to bolt single type wheels on it (with nearly no offset)?
Sounds good to me.
Does it give you the track width you need?
Bigger question is will you have a gear ratio and transmission combo that makes good use of the Diesel?
Here's a speed calculator
http://www.onlineconversion.com/bigger_tires.htm
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
i use singles on a duelly rear with no problems. mostly to cheap to buy the tires!!
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
Darenhg72 - Is it the 1952 in your profile? Any photos showing it with single rears? What size rims/tires are you running?
Moderated by  Dusty53
