| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | Can somebody tell me what the paint code and name is for the white color used on grills, bumpers, etc on a factory 1956 chevy pickup. Thanks! I looked at the paint chip codes and it showed Dover White and Alpine White. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't see the trim color specified on the 56 sheets I have, but on the 57 and 58 sheets [should be the same] it's called Arctic Beige, Dulux 93-74277 [enamel] .... don't know if that number can be crossed to anything modern
Bill | | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do you have a link to a paint sheet that shows Dover White and Alpine White for USA 1956 Chevrolet trucks? I see Pure White and there was Bombay Ivory (both from prior years) and Arabian Ivory, which was new for 1956. My guess would be Pure White was used for misc exterior and interior White (as was used from mid-1954 through 1955 - that white color was also available in many prior years). If my guess is correct, and you cannot find a color code for Pure White, instructions on how to contact the PPG Color Library are given at the bottom of the Stovebolt.com Tech Tip. Pure White: PPG 8080 DUPONT 93-21667 | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Hey nio, This LINK is to the 1955-56 color charts I have for commercial truck. Maybe it will help with codes. SEE YA! Mark | | |
