Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 49 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#878234 08/27/2012 8:21 PM
I just bought a 48 1 Ton with a stock Inline 6. The engine starts right up once you hit the starter pedal (12v) and it will idle with no problem (upwards of 15 minutes before I shut it off). What type of up keep do I need to perform to keep it running well? A full engine rebuild is in the future, but right now I want to have the opportunity to drive around a little while the weather is nice.
Redlegs48 #878254 08/27/2012 9:34 PM
The shop manual will give you what you need to do to maintain it.
1951 1 Ton Completed
Redlegs48 #878255 08/27/2012 9:36 PM
Oil change and grease job, clean the air filter, check all the lubes,fresh clean coolant and get used to the characteristics of the vehicle--it will tell you what you need to do.
Study the things needed to keep it in tune and if it aint broke don't fix it.
Bob Taylor
enginenut #878269 08/27/2012 10:04 PM
Thanks for the info, sounds like I should be able to handle that. Hopefully everything keeps working until I can better familiarize myself with the inner workings on the motor.
