| | | Forums66 Topics128,005 Posts1,055,266 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | I just bought a 48 1 Ton with a stock Inline 6. The engine starts right up once you hit the starter pedal (12v) and it will idle with no problem (upwards of 15 minutes before I shut it off). What type of up keep do I need to perform to keep it running well? A full engine rebuild is in the future, but right now I want to have the opportunity to drive around a little while the weather is nice. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The shop manual will give you what you need to do to maintain it. | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | Oil change and grease job, clean the air filter, check all the lubes,fresh clean coolant and get used to the characteristics of the vehicle--it will tell you what you need to do. Study the things needed to keep it in tune and if it aint broke don't fix it.
Bob Taylor
| | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | Thanks for the info, sounds like I should be able to handle that. Hopefully everything keeps working until I can better familiarize myself with the inner workings on the motor. | | |
