4 members (TexasJim50, 3B, Otto Skorzeny, 1 invisible), 66 guests, and 8 robots.
Topics128,013
Posts1,055,322
Members48,419
#87813 01/05/2005 9:51 AM
Hi folks,
I've had a couple of problems with the truck over the last few days that I've managed to fix. I'm going to need some help with this one though.
The truck is a 1941 halt ton with the 216. It has been converted to 12 volt with an alternator. The truck has been running great until yesterday. It started up first boot as usual but the charging light stayed on. I ran the truck for about 10 minutes with the headlights turned on to see if there was any drain on the battery. Turned it off and it cranked over quickly as usual. I had a look at it again this afternoon again no problem starting but after a couple of minutes idling it cut out. When I turned on the ignition the charging light didn't come on, neither did anything else no headlights, horn, indicators etc. The weird thing is that the foot starter still worked. It even worked with the ignition in the off position. Auto electrics are a mystery to me guys. I'd appreciate some help on this.
Cheers
Bob
#87814 01/05/2005 4:33 PM
Riding in the Passing Lane
There is a heavy gauge wire comeing off the
starter switch that feeds everything. Follow
it checking for broken wire from there to the
ign. switch & headlight switch. Leave the headlight switch on & watch for flickering lights.
Make shure you have a ground wire or cable from
engine to frame & to body. If that doesn,t find
it get a test light & chase it down. smile
1972 Chevy c10 Cheyenne Super
#87815 01/05/2005 11:22 PM
Wrenchbender,
Thanks mate I'll have a go at that.
#87816 01/14/2005 3:41 AM
Tab Offline
check your ignition switch FIRST.
delete my account and pictures
#87817 01/14/2005 9:35 PM
Update.
Problem solved. It was partly the feed to the ignition switch and partly the charging light shorting out. Wrenchbender and Tab thanks again for the help.
Bob
