2 members (Stelonlevo, dt235sd), 138 guests, and 2 robots.
Topics128,080
Posts1,056,314
Members48,442
1 Offline
1964 Chevrolet 3/4ton 4spd. I went to drive my truck after about two weeks and it wouldn't shift into gear. It made a grinding noise like the clutch wasn't disengaged enough.So i slammed it in reverse and the truck leaped back indicating that the clutch wasn't disengaged. After doing this the truck got stuck in reverse,so i readjusted the clutch linkages and i was able to shift it into neutral without the truck running. But when i went to shift it with the truck running it made the grinding noise again.
any ideas what could be wrong.
Riding in the Passing Lane
Your disc is stuck to the flywheel. You can get underneath & remove the lower cover. Prop the clutch pedal down & use something thin to pry the disc from the flywheel. Or you can prop the clutch pedal down, put the trans. in high gear & rock the truck back & forth. You will feel it when it comes loose but dont have it where it can roll away.
1972 Chevy c10 Cheyenne Super
1 Offline
Thanks il give that a try this weekend.any suggestions on how to stop this from happening again?
