Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Crimson48, Phak1, 1955 1 Series, Frank50, CuzzFuzz), 37 guests, and 1 robot.
Topics128,006
Posts1,055,272
Members48,418
#877867 08/26/2012 4:59 PM
I am having trouble figuring out the engine size in my latest barn find. Here is what is on the passenger side of the block, by the dip stick (on the polished surface) 0I73646 F54N It is in a 1951 two ton. I have spent quite a bit of time and all I can find is that it is likely a 1954 engine. Any help will be greatly appreciated, Scott
1954 Chevrolet 4400 1.5-Ton Dump Truck
1946 Chevy 1.5-Ton Dump Truck
1944 Chevrolet 1.5 Ton Dump Truck
1955 4400 Dump Truck
1951 2 Ton Stake Body
Scott54 #877881 08/26/2012 5:42 PM
http://chevy.oldcarmanualproject.com/chevyresto/54057.htm
Congratulations, that 6000 series heavy duty engine is most likely a 261.
Post the block and head casting numbers, if you wany a confirmation.
Scott54 #877893 08/26/2012 6:30 PM
Here are the head casting numbers:
B18 918
068
570
That is the way they appear on the head. Also, I see the two "captain's bars" on the block near the starter. Thank you for your reply.
Scott54 #877895 08/26/2012 6:36 PM
tclederman #877922 08/26/2012 8:06 PM
Best to use the block casting number which is located on the passenger side of the block behind the fuel pump. Not all 261's have the captains bars. I had one that didn't.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
