9 members (UtahYork, Pre '68 Dave, rfs56trk, Donf, Oldcaliforniakid, baldeagle, J Lucas, Nick in Manitou, Rusted Nut),
36
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | I am having trouble figuring out the engine size in my latest barn find. Here is what is on the passenger side of the block, by the dip stick (on the polished surface) 0I73646 F54N It is in a 1951 two ton. I have spent quite a bit of time and all I can find is that it is likely a 1954 engine. Any help will be greatly appreciated, Scott | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://chevy.oldcarmanualproject.com/chevyresto/54057.htmCongratulations, that 6000 series heavy duty engine is most likely a 261. Post the block and head casting numbers, if you wany a confirmation. | | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | Here are the head casting numbers: B18 918 068 570 That is the way they appear on the head. Also, I see the two "captain's bars" on the block near the starter. Thank you for your reply. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | Best to use the block casting number which is located on the passenger side of the block behind the fuel pump. Not all 261's have the captains bars. I had one that didn't. | | |
