| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 70 | I am working on a 53 ford 2 door the motor is free and spins so I am going to get new plugs wires ect ect and see if it will start. I am going to drop the fuel tank and blow the fuel lines out hopefully it will start. my question is can you get an electronic distributor for the flat head ? I searched e bay but only a few new models came up so I thought I would ask all the gear heads here thanks all for the help
frankenstein Fabrications
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Take a look at this site, give Henry a call. I've got one and it works great. http://www.thepitstopgary.com/ | | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | By 53, the flathead distributor had moved from the end of the camshaft to a housing ahead of the right cylinder head. It could be converted to some type of electronic trigger unit like a Pertronix, or you could adapt the MOPAR magnetic trigger system to the Ford distributor and use its pulses to fire a GM-type HEI module. Some of the Ford distributors use an oddball spark advance system with no centrifugal advance and a vacuum advance that works on venturi vacuum, not manifold vacuum. Jerry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | this flat motor was at our local show n shine a few weeks ago - heard the guy yakkin to others, apparently he rigged it himself - sweet runner ...... but this belongs in the Spoon  Bill | | | | | Joined: May 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 55 | I am running the pertronix unit on my ford f6, ford 600 tractor and 52 chevy 1.5 ton. be sure if you go that route to order the right one as they come one of two ways for the ford. six volt positive ground and twelve volt negative ground. you do not need to remove the distributor to install them. I am very pleased with the performance and money well spent in my opinion. hope that helps | | |
