1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 2,402 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,402 | How much fluid would normally be replaced after dropping the pan and changing the filter? Also, are there any good solutions to sealing the leaky dipstick tube?
I added 7 quarts to get the level up to the mark on the dipstick (after it was warmed up) and all seemed well, but after sitting for two days it started leaking puddles. It also appears to be leaking out of the speedometer port. It's currently open as it will not match up with the original speedo cable. Does someone sell a cap so I can just plug it for now?
This is not my doing, I'm just trying to patch up a hacked up job done by another many years ago.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | First it generally takes about 5 quarts to refill it after dropping the pan. Your dipstick & tube don't match. There is a grommet in the trans. where the tube go in. It must need replaceing. It shoud have a bracket on the tube that attaches to the rear of the engine or trans mounting bolts. There is a tiny seal in the speedo cable outlet. It will need repaceing also. I dont understand why the speedo cable will not fit. They used the same trans. end for many years. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | There is a very small lip seal around the speedometer drive gear shaft that should prevent leakage even if the cable isn't connected. They're bad about failing, however.
Another source of leakage that's often overlooked is a tiny weep hole in the center of the sliding yoke at the front of the driveshaft. It's there to keep air pressure from building up in the yoke, but if the fluid level gets above the centerline of the output shaft due to the torque converter leaking down, fluid can seep down the splines and find its way out the yoke vent hole. The simple fix is to braze up the hole in the yoke to keep the fluid from leaking out in case the converter leaks down. Jerry
| | | | | Joined: Nov 2004 Posts: 2,402 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,402 | Engine and transmission is late 70's and the truck is a '59 Apache that (I believe) was probably a factory 6 cylinder 3 speed.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Nov 2004 Posts: 2,402 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,402 | Once again it looks like George was right. It appears that the cable (I mean a new one) will most likely work. The old one was apparently cobbled up many years ago. I was able to siphon two quarts of tranny juice out of the dip stick tube. Tomorrow I will hopefully get those leaks fixed.
So far, all I see is an o-ring sealing the dip stick tube is that correct?
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | John, I've seen some after market stuff that use an O-ring but I think originally they had sort of a "sleeve/or sock" that went into the tranny then the dipstick housing pushed down into it....maybe someone can confirm or learn both of us something!! | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Early model dipstick tubes used an O ring about 1/8" thick by about 3/4" diameter. Later, the shape of the tube was changed, and a rubber sleeve about 1 1/2" long was used as a seal. To switch from the O ring to the sleeve, you would need to change the dipstick and the tube to the later model items. The sleeve seal does a MUCH better job of preventing leaks! Jerry
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Also if you don't replace the seal in the speedometer gear or you will still have a leak even with the new cable connected. | | |
