Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 44 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#877212 08/24/2012 10:22 AM
Hello, Just curious, would you convert regular cab to five window or find a cab that is already five window ? I always liked the five window cab.
Its your truck. Do what you want to it.
Give me ambiguity
or give me something else
Can you cut sheet metal, weld, and do body work?
Y
Y Offline
My 53 started life as a 3 window. I cut the cab @ the windshield and rear floor. Note: I took the best of both cabs in order to build my truck. Some bolters have sectioned in the corner windows. Do a search and the info will turn up.
I've seen a guy convert a five window to three. As the other's said, if you can cut and weld, there are pre-made panels/skins available and, it's your truck, do what makes you happy.
If it were me and my cab were a three window in the same condition my current cab is in, I would look for a five window cab first that didn't have any rust or other major defects, as mine has a bit of boot rot. They can be had pretty cheap and, if you can find one locally, will take less effort than welding in an inner and outer upper rear cab section or corners. Cutting and welding would be my plan B. ...but thats just my take on it.
Thanks, That was my thought.If I could find a good cab may be the best route as my cab does need a bit of work.I am good a replacing sheet metal , I restored a 57 Chevy.
