7 members (fonz8261, Rexville48, 1955 1 Series, Peggy M, mk72, Shardean, 55shaker),
60
Mod | | | Forums66 Topics128,022 Posts1,055,387 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 15 New Guy | | New Guy Joined: Apr 2012 Posts: 15 | on my 235 i have a rocker arm oiler it is missing the tube that comes from the head to the rockers when i get a new one i was wondering if anyone has put a screw type seal from the head on the tube or would this be a good idea? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | No seal needed. What year 235, it makes a difference on what rocker connecter tube you need.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2012 Posts: 15 New Guy | | New Guy Joined: Apr 2012 Posts: 15 | i have checked the #s and it looks like it was made in 55 or 56 the reason i was thinking about this is that i would get the full oil pushed thur the rockers before the oil returns to the pan. i am in the process of rebuilding the 235 an will be putting a full oil pressure system in the engine.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I am in the process of rebuilding the 235 an will be putting a full oil pressure system in the engine. Could you explain? 1955-56 engines are full pressure already, unless you are talking about using 1959-62 rockers, which had the shafts pressurized.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Maybe faynelong is referring to a full-flow oil filter conversion, which would have little to do with rocker arm lubrication?
| | | | | Joined: Apr 2012 Posts: 15 New Guy | | New Guy Joined: Apr 2012 Posts: 15 | the 235 does have lubrication tim is right i am planning on doing a full-flow oil filter conversion. the reason im asking about the rocker arm oiler is one of the rocker arm shafts was wore badly i also think it was installed wrong the oil hols were at the bottom i think they should be at the top but i was just thinking maybe i could get more oil to the rockers by making the rocker oiler sealed to the head just a thought and give the rockers more oil i did not do any work on this engine when i got it was the way i mentioned | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | ....i also think it was installed wrong the oil hols were at the bottom i think they should be at the top.... The holes are supposed to be on the bottom on the low pressure engines. I assume they didn't change it with the full pressure engines. With the holes on the bottom the rockers start getting oil sooner than they would if they had to wait for the shafts to fill.
