| | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 19 'Bolter | | 'Bolter Joined: May 2010 Posts: 19 | Hello fellas! Would a 2 ton art deco(41-46) truck grille fit a half ton truck ( are they the same )? I know th big AD (47-54) truck grilles are bigger than the half tons. Thanks | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I know the fenders are different, but unfortunately I'm unsure of the grille. Someone might know for sure, but your best bet might be to get measurements and compare to the 1/2 ton opening, or 1/2 ton measurements (which I can get for you next weekend). | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | They are the same so far as I know. I layed a 1 1/2 ton grill atop a 1/2 ton, and everything appears the same.
Jeff | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | A friend has a '40 well drilling truck, must be a 1 1/2ton or so, and it is the same front clip (except the fenders to clear the big tires,) as my pickup. And the '40 is the same cab as the '41-'46.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
