| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87751 03/02/2004 5:45 PM | Joined: Sep 2002 Posts: 12 Member | | Member Joined: Sep 2002 Posts: 12 | hi does any one know if the aftermarket new harnesses have all the end connections and bulbs to hook to heater switch dash cluster etc to rewire the whole truck does any one know a good place to purchase one ive never done wiring before beginner ex:painless | | |
#87752 03/02/2004 5:59 PM | Joined: Oct 2000 Posts: 108 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 108 | Mitch,
Are you going for a complete stock restoration or are you building a street rod? Makes a difference in my opinion as to what you get. For instance,I wouldn't use a painless wire harness with a frame up back to stock truck. If you get a reproduction harness for your year it should have the correct length of wires and connectors, etc. | | |
#87753 03/03/2004 2:04 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you are going stock I'd reccommend the Chevy Duty harness. It has all the wires cut to length, terminals installed and sockets for the dash bulbs.
If you are building a custom I'd go with the painless. I looked at them at a distributor's display at the swapmeet last weekend. I was very impressed. They come with a modern style fuse box complete with fuses and flasher, in either 12 or 18 curcuit. Of course being for custom installations you have to cut the wires to length and crimp your terminals. The sales guy said there's usually plenty of leftover wire. | | |
#87754 03/03/2004 5:29 AM | Joined: Sep 2002 Posts: 12 Member | | Member Joined: Sep 2002 Posts: 12 | thanks alot for help im going stock sounds easier | | |
#87755 03/03/2004 4:36 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | EZ-Wire is the same as Painless ... only a LOT less money! Yo' Mitch -- I had a blast rewiring my truck, and with the EZ-Wire kit you have extra fuses, etc. in case you want to add anything to your truck ... like I did ... for only $165 You can get the links and see my whole install Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
