2 members (Otto Skorzeny, TexasA&M48Truck), 144 guests, and 3 robots.
Topics128,095
Posts1,056,480
Members48,444
hi does any one know if the aftermarket new harnesses have all the end connections and bulbs to hook to heater switch dash cluster etc to rewire the whole truck does any one know a good place to purchase one ive never done wiring before beginner ex:painless
Mitch,
Are you going for a complete stock restoration or are you building a street rod? Makes a difference in my opinion as to what you get. For instance,I wouldn't use a painless wire harness with a frame up back to stock truck. If you get a reproduction harness for your year it should have the correct length of wires and connectors, etc.
If you are going stock I'd reccommend the Chevy Duty harness. It has all the wires cut to length, terminals installed and sockets for the dash bulbs.
If you are building a custom I'd go with the painless. I looked at them at a distributor's display at the swapmeet last weekend. I was very impressed. They come with a modern style fuse box complete with fuses and flasher, in either 12 or 18 curcuit. Of course being for custom installations you have to cut the wires to length and crimp your terminals. The sales guy said there's usually plenty of leftover wire.
thanks alot for help im going stock sounds easier
EZ-Wire is the same as Painless ... only a LOT less money!
Yo' Mitch -- I had a blast rewiring my truck, and with the EZ-Wire kit you have extra fuses, etc. in case you want to add anything to your truck ... like I did ... for only $165
You can get the links and see my whole install Here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
