| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Hi Guys, 2 questions if you would.. seems like one of my lifters will not compress. I pulled out the lifter but I don't know if it's good or bad.. Other question is re/ this I have hydraulic lifters so am I to adjust w/ no clearence? In other words according to what I am reading I do not have to use a feeler gauge but I do need to adjust in the proper order. Am I correct??
Try prayer as the first response rather than a last resort ...
| | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | Yes adjust to the proper order . | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | I won't venture in on the setting procedure, many others more experienced on the 'bolt that can tackle that.
A lifter full of oil may seem "solid"' depending on what you try to compress it with. It will certainly feel solid if you try to compress it by hand. If it's ingested air it will feel soft or spongy.
If you want to check it for function, you can immerse it in a cup of light oil (industry used to use kerosene), put it in an arbor press, and force the socket all the way down. This may take a couple hundred pounds, depending on the lifter, the weight of the oil in it, and particularly temperature. If the socket stays down when you release the load, the lifter is bad. A "spongy" lifter will usually emit a stream of bubbles as the air is compressed out. If the spongy lifter does not go "solid" after many full strokes, it's bad.
They are neat devices, simple in function, but intricate in design and manufacture. The inner plunger and body are class fit to a clearance of about 3 microns (125 millionths of an inch), so they are very sensitive to dirt. Be careful with them out of the engine. If you do take one apart, you cannot mix parts between assemblies.
Good luck and have fun.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Thanx for your reply.. I put the lifter back in. If it works it works.. Otherwise gues I'll have a bent push tube. I did compress it and it came back up but I only compressed it maybe a 1/4 inch. Will try and start tomorrow.. Jack
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Put the lifter in a cup of clean oil and pump it up (get the air out) before reinstalling it. Mike B  | | | | | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Thanx Mike will do. Probably easier to remove the side plate again rather than risk it... and have to do it again anyway. JACK
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Adjusting hydraulic lifters is a little tricky. If you know someone who has done it, get a 6 pack and invite them over.
You have to adjust lash until there is no slack then an addition 1/2 to full turn.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Thanks! Haven't had a chance to do anything yet . Probably Tuesday.. By the way last six pack I had was when I was 17 or 18 yrs old..
