6 members (Samantha, dt235sd, homer52, chevyb, wilbur53, 32Fordpuchoptop), 122 guests, and 4 robots.
Topics128,088
Posts1,056,124
Members48,435
I have the old one cut out, but I cant figure out how to get the window out. I have unbolted the bottom pivot, but cant seem to figure out how to get it out. Does the bottom pivot screw into the window? Help!
1950 Chevy 3600
Is this for your '50? I thought that vent windows were introduced in 1951. If yours are like the ones in my '54, you must drill out the pivot rivet to remove the vent window. Then install the new rubber. Position the vent and replace the rivet.
Vent window pivot rivets and rivet setting tools are available from most supplers. I was lucky. I found it pretty easy to set the rivet. Alvin replaced his rivot with a special bolt. He can tell you how he did it.
I assume that you are doing this with the vent assembly removed from the door. Don't think I would want to try to set the pivot rivet while the assembly is in the door.
Note - the rubber seal overlays the window garnish. A little dish washing liquid may ease it into postion.
- Lonnie
My '54 3104
Thanks, yeah this is for my 50 but the windows are from something newer. I appreciate the advice. I wish they would have made it easier.
1950 Chevy 3600
...I drilled out my pivot rivits. The rivets, and the tool, that I recieved were a booger to use and I was never able to set a rivet they sent me.
...so, I took one of the pivet rivets to my local machine shop guy and had him to make me some "bolts" out of stainless steel just like the rivit....but with some threads on the bottom. I then got me a nylon nut and screwed on it. Man, no more banging the rivet for me.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/wingventrivet004.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/wingventrivet001.jpg
I still need to cut just alittle off the bottom. The next ones I have him make will be a little shorter.
Another method is to simply drill out the two rivets that hold the pivot assembly to the frame. They are easy to get to with a close quarter drill and it takes less than 5 minutes (no cussing, swearing or pounding!). I will simply re-rivet or spot weld the pivot assembly back in place to the frame when I am finished cleaning and rebuilding.
