2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#876509 08/21/2012 6:33 PM
Is swapping out a leaking differential seal a big deal? Can I do it in the driveway without jacking up the rear?
"Happiness equals reality minus expectations" - Tom Magliozzi
Jim Bow #876522 08/21/2012 7:27 PM
back yard wrench turner
You are talking about the pinion seal?
It will be easier if driven up on ramps to give you more clearance.
You may have difficulty removing the pinion nut. Other than that it's a straight forward deal.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Wayne67vert #876584 08/21/2012 10:32 PM
Riding in the Passing Lane
I agree with Vert if it is a 1/2 ton. 3/4 ton up is harder to do.
1972 Chevy c10 Cheyenne Super
Jim Bow #876803 08/22/2012 8:58 PM
I have a 58 half ton and I changed mine without jacking it up. But mine has a piece of plywood bolted in the bed and when it is removed you can stand inside the bed with both feet on the driveway and work on everything. I have pulled the chunk from the rear that way. It will stay that way because I'm way to old to crawl around under there until something breaks under the front half.
6571 #877161 08/24/2012 4:35 AM
If you want to do it correctly its a big deal. Need a new crush sleave and proper preload.
Truckrolet #877281 08/24/2012 2:54 PM
I have 32" tires on my half ton. There is plenty of room under it to do that job, or change a clutch for that matter, without jacking the truck up. I love it.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
enigmaT120 #877283 08/24/2012 3:23 PM
I am now replacing the rear pinion bearings and seal on a biggish truck (54/55 2-ton COE with 2-speed rear). I do not have it jacked up. I can easily work under this one on my driveway. grin
Truckrolet #877450 08/25/2012 12:03 AM
We don't even have a clue as to what he's working on. ohwell
My 1953 Chevrolet
1947.1 Gallery
rustednuts #877643 08/25/2012 7:22 PM
If you have not done rear end work, setting pinion height or depth which ever you want to call it. And setting pinion bearing preload. Gear contact pattern, and back lash, and carrier bearing preload. Its probably best to take it to some professional differential outfit and let them eat it if it is setup improperly. Done wrong they don't last long and sound horrible, and really chew things up nicely.
