5 members (Opelika Tom, Otto Skorzeny, MikeE, Wayne67vert, TexasA&M48Truck), 62 guests, and 0 robots.
Topics128,091
Posts1,056,037
Members48,433
#818960 01/23/2012 5:48 PM
1 Offline
Did big bolts have different dash radio hole size and different radios? i pulled a radio out of a big bolt and when i went to out it in my 1/2ton it didnt fit in my radio hole. The radio i pulled wasnt stock because the lettering and numbers where up side down. But it looked old and i was going to use just for looks.my truck is a 47-53 chevy and the big bolt was the same year period
Could you give some more detail about the Big Bolt? there was a very large GMC Diesel that had a different cab and a different radio. Did the inside of the cab look like yours?
What is the name on the radio? There were Canadian radios called "GM Auto Radio" that were made for use in the truck and in some cars. The front controls were adjustable in the width of separation and also the front angle. The radios used a different dial glass in different applications as one was upside down from the other.
1951 1 Ton Completed
I think it's possible the radio is for a GMC,due partly to not fitting the radio hole and partly due to the lettering being upside down.Radio units like the one for my '54 GMC have the tuner on the left and the volume control on the right,backwards from what is typical. Thus,trying to install it with the volume control to the left would make it upside down,and it wouldn't fit the hole.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
I think a photo would be helpful here.
Moderated by  truckernix
