9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible), 189 guests, and 2 robots.
Topics128,080
Posts1,055,952
Members48,430
#873744 08/10/2012 2:17 PM
I need a flywheel for a 58 235 are all years the same from 54 to 62 ? I found a flywheel that was supposed to fit but the dowel pins and bolt holes do not align thought it may be for a small block
Your best bet is to get one from 1956 or newer 235 or 261. Your truck is most likely 12v and the 12v starter works with a "12v" flywheel, which has more teeth than a 6v flywheel (168 vs 139, I think).
Last edited by tclederman; 08/10/2012 8:12 PM. Reason: added specific reference to sizes of engines
Thanks that was what I was thinking but had not ran into the source for the information
Riding in the Passing Lane
The v-8 wont fit.
1972 Chevy c10 Cheyenne Super
I have 2 flywheels just sitting in the back of my truck. The one pictured has 168 teeth.
flywheel
That is the one
pm sent
Hope I can reopen this topic. I have a 261 engine from a 1960 Canadian Pontiac which had a Powerglide auto transmission with 168 teeth. I also have a 235 flywheel with 4 bolts on the crank flange.The 261 crank has 6 bolts and 3 dowels like the one showen by New Ton. Did 235 engines also have 6 bolt cranks? I too would like to get such a flywheel. Where should I look (other than the back of New Ton's truck) Gord
Gord
4 bolt flywheels stopped in 1939 for Chevs, GMC's kept them much longer.
From 1942-62 216's, 235's and 261's all have the same crank bolt pattern. You just need to use one that matches the starter (6 or 12 volt), and clutch size you plan to run.
My Blog
ODSS Lawman
ODSS Lawman
What is the tooth count? You may have a flywheel the GMC 302 guys would pay a pretty penny for..
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
The flywheel is from an inline six maybe a 235. It has 139 teeth. The diameter is about 14 in. It is about 2.25 in. thick, but the clutch surface is recessed 1 in. The pressure plate is 10.25 in. and the friction plate is 9 in. Gord
Gord
Gord,
A 139 tooth flywheel would have been 6v but it would not have been off a 235, which used 6 bolts (as described above, by Dave). It might have been off a 216, which were introduced in 1937, but 235s were introduced in 1941.
Is there a casting code on the flywheel?
Also, Dave's information is for USA engines - there might have been differences in Canadian engine?
There are two numbers on the flywheel 838174 and A167
On the attached crank is 838877 on one of the balance nodes
I recall that there were semi circular replacable bearings on the engine.
Gord
