| | | Forums66 Topics128,052 Posts1,055,719 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Is swapping out a leaking differential seal a big deal? Can I do it in the driveway without jacking up the rear?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | You are talking about the pinion seal? It will be easier if driven up on ramps to give you more clearance. You may have difficulty removing the pinion nut. Other than that it's a straight forward deal.
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree with Vert if it is a 1/2 ton. 3/4 ton up is harder to do. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I have a 58 half ton and I changed mine without jacking it up. But mine has a piece of plywood bolted in the bed and when it is removed you can stand inside the bed with both feet on the driveway and work on everything. I have pulled the chunk from the rear that way. It will stay that way because I'm way to old to crawl around under there until something breaks under the front half. | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | If you want to do it correctly its a big deal. Need a new crush sleave and proper preload.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | I have 32" tires on my half ton. There is plenty of room under it to do that job, or change a clutch for that matter, without jacking the truck up. I love it.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I am now replacing the rear pinion bearings and seal on a biggish truck (54/55 2-ton COE with 2-speed rear). I do not have it jacked up. I can easily work under this one on my driveway. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | If you want to do it correctly its a big deal. Need a new crush sleave and proper preload. We don't even have a clue as to what he's working on.  | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | If you have not done rear end work, setting pinion height or depth which ever you want to call it. And setting pinion bearing preload. Gear contact pattern, and back lash, and carrier bearing preload. Its probably best to take it to some professional differential outfit and let them eat it if it is setup improperly. Done wrong they don't last long and sound horrible, and really chew things up nicely.
