6 members (baldeagle, tclederman, TexasJim50, carbking, Hotrod Lincoln, 1 invisible), 79 guests, and 4 robots.
Topics128,018
Posts1,055,341
Members48,419
#876293 08/20/2012 9:55 PM
Does anyone know if there is such a thing as a universal backup switch for a floor mount 4spd? I have no backup lights, and I am assuming that it is because the shifter was moved from the column to the floor. I assume that this also means that the transmission isn't original.
So, is there a universal part that I can install? Or do I need to find something specific to the transmission?
Sometime in the late 50s I believe, there was an optional switch that mounted on the shifter tower to control a backup light. I have seen it but can't remember the details.
1951 1 Ton Completed
yes, there's a back up light switch 'kit' as nix says - you might be able to find something 'generic' at a parts store, or try a post in the Parts Wanted or keep an eye on e-bay, they come up occasionally - consists of a mount for the switch and a tab on the lever that depresses the switch when you move to reverse
There was a fed govt required backup sitch on SM420 transmissions in its last year, 1967.
Here is a little write-up of the add-on back-up switch that I think that Bill is referring to.
Here is an installation diagram. (posted by 4-5-6 Chevy Trucks)? Here is the full thread.
yes, the setup in the Flickr scan, and the reference at Carters was available as an option at least from the 55 2nd
I think Lokar makes one for auto trans linkage - might work on a manual setup ?
1940 Chevy KC 1/2-Ton
