7 members (51sub, Wheelie, baldeagle, Ponchogl, cmayna, fonz8261, Peggy M),
48
7
Mod | | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 36 New Guy | | New Guy Joined: Jul 2012 Posts: 36 | Does anyone know if there is such a thing as a universal backup switch for a floor mount 4spd? I have no backup lights, and I am assuming that it is because the shifter was moved from the column to the floor. I assume that this also means that the transmission isn't original.
So, is there a universal part that I can install? Or do I need to find something specific to the transmission? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Sometime in the late 50s I believe, there was an optional switch that mounted on the shifter tower to control a backup light. I have seen it but can't remember the details. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, there's a back up light switch 'kit' as nix says - you might be able to find something 'generic' at a parts store, or try a post in the Parts Wanted or keep an eye on e-bay, they come up occasionally - consists of a mount for the switch and a tab on the lever that depresses the switch when you move to reverse
Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, the setup in the Flickr scan, and the reference at Carters was available as an option at least from the 55 2ndBill | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I think Lokar makes one for auto trans linkage - might work on a manual setup ? | | |
