6 members (1955 1 Series, 53again, Cosmo, Hotrod Lincoln, mason86, Gray_Ghost), 100 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#87625 10/08/2002 9:15 PM
Hi, I have a 54 GMC 100 with a 248 engine and I believe all or mostly all original type equipment. I'm new to all this and would like some advice. I have a new 6 volt battery and the truck starts with no problem. However the ammeter appears to read the opposite that I would expect. When the engine is running it moves to the left (-) and if I turn the lights on it moves back toward the middle. If the engine is not running and I turn the lights on it moves to the right (+). Shouldn't it be the other way around. I checked the voltage on the battery and it read 7 when the truck wasn't running and about 8.7 when it is running. Does this mean the system is charging okay? I also tried repolarizing the generator. Thanks for any help
#87626 10/08/2002 9:38 PM
Your GMC truck is positive ground. That means the plus terminal of the battery should be grounded to the frame.. Is it hooked up that way ?
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#87627 10/08/2002 9:50 PM
I'm not sure. I will check it out. Thanks for the suggestion.
#87628 10/09/2002 2:42 PM
That was the problem. The battery was not connected properly. Thanks again
#87629 10/09/2002 10:54 PM
Glad to see you got it straightened out..
Bill M
53 GMC Hydra-Matic
Home Page
#87630 10/11/2002 4:38 AM
Glad to see you have it (properly) GROUNDED out grin
