2 members (Cosmo, Gdads51),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,798 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87625 10/08/2002 9:15 PM | Joined: Sep 2002 Posts: 9 Member | | Member Joined: Sep 2002 Posts: 9 | Hi, I have a 54 GMC 100 with a 248 engine and I believe all or mostly all original type equipment. I'm new to all this and would like some advice. I have a new 6 volt battery and the truck starts with no problem. However the ammeter appears to read the opposite that I would expect. When the engine is running it moves to the left (-) and if I turn the lights on it moves back toward the middle. If the engine is not running and I turn the lights on it moves to the right (+). Shouldn't it be the other way around. I checked the voltage on the battery and it read 7 when the truck wasn't running and about 8.7 when it is running. Does this mean the system is charging okay? I also tried repolarizing the generator. Thanks for any help | | |
#87626 10/08/2002 9:38 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Your GMC truck is positive ground. That means the plus terminal of the battery should be grounded to the frame.. Is it hooked up that way ?
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#87627 10/08/2002 9:50 PM | Joined: Sep 2002 Posts: 9 Member | | Member Joined: Sep 2002 Posts: 9 | I'm not sure. I will check it out. Thanks for the suggestion. | | |
#87628 10/09/2002 2:42 PM | Joined: Sep 2002 Posts: 9 Member | | Member Joined: Sep 2002 Posts: 9 | That was the problem. The battery was not connected properly. Thanks again | | |
#87629 10/09/2002 10:54 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Glad to see you got it straightened out..
#87630 10/11/2002 4:38 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Glad to see you have it (properly) GROUNDED out
