5 members (Otto Skorzeny, jmoore, Hotrod Lincoln, Bill Hanlon, Ponchogl), 127 guests, and 0 robots.
Topics128,105
Posts1,056,209
Members48,436
#876061 08/20/2012 3:15 AM
Well - I have some issues with the posting as I copy/pasted so I'm using the edit function now.
Been lurking here since last autum when my eldest son got a GMC 1/2-ton long bed from 1951. It had been sitting since 1980 and last winter and spring when put some work in to it haveing it running. I do the mechanics and the son the sheet metal work and the younger son helps out with both.
Early July we got it on the road and the son has been using it as his DD to and from work.
I'm new to trucks and GMC/Chevy - I have a Desoto S11 from -48 and we have some other old American Iron within the fammily - but i hope to be able to contribute in some way !
//d
hmmm - I have posted in the "driveline" section but the topic ain't visible to me. So - what do I do wrong ?!
You have done nothing wrong. This is a problem that some people are experiencing intermittently.
Try to type in your message rather than using cut-and-paste.
If there is an option below the bottom right of the edit/reply box that says "Switch to Full Reply Screen", select that option.
Also, there might be a drop-down menu at the bottom left of this box. If there is a choice, select "Using UBBCode and HTML"
Good luck,
That is what I did e.g. copy/paste as I whanted to spell check it before I posted.
Thanks tcledarman!
Just one quick question - can you read my post in the driveline section ?
I see that someone has viewed it but I can't my self frown
//d
welcome, yes we can see your post, not sure why you can't.....
we have been watching a series on TV about the Baltic states,
I would love to go to Sweden and tour around the Baltic coast, what a neat deal..........
Redryder pix
My Hotrod
joker #876151 08/20/2012 12:39 PM
Welcome to the board!!!! should have everything ya need!!!!
After searching for a year I found the next project!
46' 1/2 ton in pieces! took 2 trips to get it home, but most of the hard work was already done!!!
-jerry
"Phil" the 46'
Leo Offline
Moderator
Moderator
Welcome Fogelgren.
Leo #876357 08/21/2012 2:33 AM
Welcome from just over the North Sea,it's always good to have another Eurobolter joining the ranks.
Good luck.
Jock.
More pix on Flickr.
24601
Välkommen Fogelgren! We have a few active Svenska who will hopefully be chiming in before too long ...
Be sure to check out the rest of the web site as we are more than just a mere discussion board. Use the menu bar at the top of the page to explore the rest of the site.
And ask lots of questions. We like questions (even if we've answered them before smile ) -- it's how we all learn!
Ses senare!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Welcome for Mississippi. Steven, Red 49 Truck
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
