BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
0 members (),
570
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jul 2011 Posts: 257 Shop Shark | Shop Shark Joined: Jul 2011 Posts: 257 | Background: Bought a rebuilt engine from a guy in the Vegas area, It sat for several years before he sold it to me. SInce then I have installed and done the necessary break in to get it going, but now It's leaking at the Main Bearing seal. I have done research via stovebolt and it seems that when an engine sits for a while ( even if rebuilt ), that seal tends to dry up and leak. I have also done some searching around and there seems to be two style of seals, one " rope " and the other neoprene. There also seems to be a grey area for what year block uses what seal? My Block code is : 3738307 which puts it in the 58-62 range. I have pulled the Main Bearing Cap off and I have the neoprene seal, but there are two metal shims on either side. With the research I have done it seems, if the shims are there I need to use a rope style, but I have the neoprene installed. Do I have the wrong seal installed, if so, is that the reason for the leak? Please help | | | | Joined: Jan 2001 Posts: 5,320 'Bolter | 'Bolter Joined: Jan 2001 Posts: 5,320 | If you study closely you will see that the shims hold the inner ends of the neoprene seal apart causing a leak. It is unusual for a 1956-62 engine to have shims. I would Plastic-Gauge the bearing to see if the clearance is correct. To much clearance will make it hard for any seal to work.
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Jul 2011 Posts: 257 Shop Shark | Shop Shark Joined: Jul 2011 Posts: 257 | I would Plastic-Gauge the bearing to see if the clearance is correct. To much clearance will make it hard for any seal to work. What is Plastic Gauging? Can you further explain this and how to do it, what tools etc.....? | | | | Joined: Aug 2011 Posts: 687 Shop Shark | Shop Shark Joined: Aug 2011 Posts: 687 | Plasti-gauge is bascially a piece of wax. You lay it on between the main bearing and the crank journal, then torque the main bearing down. Then remove the main bearing and use the gauge that comes with the plasti-gauge to see how much the wax expands. That will tell you the clearance. I'm thinking you should have between .001 and .003 but check the books. Here's a pic. plasti gauge The good part is that you can pick up a plasti-gauge at any parts store for about $3.. or less! Hope this helps
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Jul 2011 Posts: 257 Shop Shark | Shop Shark Joined: Jul 2011 Posts: 257 | I'm thinking you should have between .001 and .003 but check the books. So if I do have between .001 and .003 clearance, what type seal do I need? I'll pick up one of those plastic gauge kits.
| | | | Joined: Jul 2011 Posts: 257 Shop Shark | Shop Shark Joined: Jul 2011 Posts: 257 | It is unusual for a 1956-62 engine to have shims. To much clearance will make it hard for any seal to work. All the Bearing Caps have these " Shims ". Did the shop ( unknown to me ) that put the engine together not know what the heck they were doing??? | | | | Joined: Jan 2001 Posts: 5,320 'Bolter | 'Bolter Joined: Jan 2001 Posts: 5,320 | It is possible the crank was turned a slight oversize making it necessary to use shims for bearing clearance.
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Jul 2011 Posts: 257 Shop Shark | Shop Shark Joined: Jul 2011 Posts: 257 | So can I assume that since I have the shims on all bearing caps that I need a rope style seal instead of the neoprene??
| | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | Not necessarily. If the shim fits properly, going all the way under the bearing shells, the lip seal will work OK. Do the clearance check with Plastigauge, and see if the shims are necessary. You might be able to remove them and not tighten up the oil clearance excessively. Remove one set of shims at a time, check the clearance as you go, and see what the oil clearance is without them installed. Don't go below .001" clearance. Green Plastigauge will be the right color for .001"-.003" checking. The red or blue will be too thick. Jerry Jerry
| | | | Joined: Aug 2011 Posts: 45 Wrench Fetcher | Wrench Fetcher Joined: Aug 2011 Posts: 45 | If the engine is still in the rig, make sure that you hold a slight upward pressure on the crankshaft. This is needed because the shaft hangs down slightly away from the upper bearing and will not give a correct reading using plastiguage. A small jack will work, with only slight pressure on the crankshaft.
The older I get, I only want to work on older rigs.
| | | | Joined: Jan 2001 Posts: 5,320 'Bolter | 'Bolter Joined: Jan 2001 Posts: 5,320 | Unfortunately the oil will find its way between the shim and the OD of the seal then. Some sealer in the right place may stop this. BTW try the pic again.
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Jul 2011 Posts: 257 Shop Shark | Shop Shark Joined: Jul 2011 Posts: 257 | Huh, I don't know why the links went away. I reposted them. | | | | Joined: Jul 2011 Posts: 257 Shop Shark | Shop Shark Joined: Jul 2011 Posts: 257 | Pre '68 Dave. Can you please look at the bearing surface and tell me what you think? Thanks | | | | Joined: Aug 2012 Posts: 402 Shop Shark | Shop Shark Joined: Aug 2012 Posts: 402 | just put a rope seal in it and forget about it, fit it with tight ends. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | Joined: Jan 2001 Posts: 5,320 'Bolter | 'Bolter Joined: Jan 2001 Posts: 5,320 | It sure looks like some grit has gone through that bearing. Have you checked bearing clearance?
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Jul 2011 Posts: 257 Shop Shark | Shop Shark Joined: Jul 2011 Posts: 257 | Thanks for the reply. I have not yet, I was looking for your opinion to see if it was too far gone to even do check for clearance. | | | | Joined: Jan 2001 Posts: 5,320 'Bolter | 'Bolter Joined: Jan 2001 Posts: 5,320 | There are so many ways to build an engine, depending on how picky one is and how much money they have. It is always tempting to make everything perfect. Some of the engines I threw together just to get by seem to run the best, and the ones where everything was done right seem to give the most problems. If the bearing clearance is .002-.003" I would not scrap it and start over, it could out last you.
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Mar 2002 Posts: 9,112 'Bolter | 'Bolter Joined: Mar 2002 Posts: 9,112 | It would be interesting to see how that seal sits in the groove. If you remove the shims on one side, it would show. Also, it might be helpful to pop the bearing shell out and see what is stamped on the back. | | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | Here's a suggestion- - - -how about adding a thin piece of shim stock between the lip seal and the block and cap after trimming the shim so the seal ends can meet? For instance, if the shim between the block and cap is .002", cut a piece of .001" stock the width of the seal, and lay it in the groove in the block and the cap before installing the seal. The ends of the seal will meet, and the pressure on the crank hub will be the same as if the shim was not there. When adjusting clearance on stovebolt rods and mains, I never use pre-made shims, I just cut my own from a big roll of shim stock I've had for years. The same stuff could be used for shimming the fit on a lip seal. Jerry
| | | | Joined: Jun 2009 Posts: 1,596 'Bolter | 'Bolter Joined: Jun 2009 Posts: 1,596 | I feel that I have better answers to your question as I went through the exact same thing on a '62 235.
The old rope seals are very old technology. The reason your engine likely has a neoprene seals is that they are much less likely to seep and leak than the rope style, and will hold up better. You can get a neoprene seal meant to reaplce the original rope seal for exactly this reason.
While I know all the books show that you need 0.001" to 0.003" clearance on the rear main, but I had 0.003" clearance and siezed the rear main 2 times. I took it to an old engine builder and we looked it over, and he told me to get a shim kit, and I did. We shimmed out the rear main further and it worked well. If it's just the rear main that's leaking, focuse on that, but don't take shims out as you could be causing issues with the bearing.
| | | | Joined: Mar 2002 Posts: 9,112 'Bolter | 'Bolter Joined: Mar 2002 Posts: 9,112 | Well your photos appear to show a bearing with the babbit worn down to the copper, right near the parting line. That might happen if you had a .002 undersize bearing fitted on a standard journal. That is why I asked what was stamped on the back of the bearing. Have you determined why the seal leaked? | | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | Definitely do not remove the shims! If you choose to stay with the lip seal, you'll need to trim the shims to let the ends of the seals butt together, and maybe add a strip of shim stock behind the seal pieces in the block and the cap. A little brush-on sealer like Permatex Super 300 on the back side of the seal halves might be a good idea, also.
Or, you can use the rope seal. It's not uncommon to get a slight amount of seepage with the rope seal, so if a few drips on the garage floor upsets you, better make the lip seal work some way or another! Jerry
| | | | Joined: Jan 2001 Posts: 5,320 'Bolter | 'Bolter Joined: Jan 2001 Posts: 5,320 | I would say the bearings were set up to tight to start with. With .001" now it must have been tighter to start with, .001' is the minimum you want, and that is with a align bored engine. I like .002" clearance. I would also Plastigauge the rest of the bearings.
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | 'Bolter Joined: Jun 2009 Posts: 1,596 | 0.001" is still too tight, these engines like to be more like 0.004" or so. | | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | That much clearance will guarantee a rear main seal leak, no matter what kind of seal is used- - - -the seal can't maintain contact with the crankshaft as it bounces around like a BB in a boxcar. Jerry
| | | | Joined: Mar 2002 Posts: 9,112 'Bolter | 'Bolter Joined: Mar 2002 Posts: 9,112 | I can testify to what Jerry just said! | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | 'Bolter Joined: Jun 2009 Posts: 1,596 | MIne didn't leak with that much clearance. As long as it lasted, at least. | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | 'Bolter Joined: Mar 2005 Posts: 1,513 | these engines like to be more like 0.004" or so. Requiring that much clearance on a rear main means: 1. The crankshaft is bent. 2. The bearing journals are misaligned. Nowhere in this thread was mention made of the alternative method of machining the back of the block/cap for a modern lip seal as I intend and is described here.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | 'Bolter Joined: Jun 2009 Posts: 1,596 | You don't need to machine the block/cap for the neoprene seal, just if you want the style he's talking about, to be clear.
The experienced engine builder I took my motor to checked everything, and the crank had been machined on a lathe and was straight. He had rebuilt numerous 235's over the years and said they alway like more than the 0.003" max clearance in the books. | | |
