2 members (Jon G, Gray_Ghost),
124
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,334 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Ive got a 54 1/2 ton chevy and it needs wheel bearings. Does anyone have the tapered bearing and seal numbers? My local auto parts store all have these young guys working there and none of them know how to use a book to cross reference numbers.if its not on a computer screen they are lost. Thanks for the help | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Call Timken at 330-438-3000. Still Made in America! | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | You could ask the young boys at the counter to let you look in the books. They would probably be happy to leave you to it. Then you could show them "how its done".
Pass the knowledge on.
Kurt | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't blame it on the young'uns, you won't find any cross reference for a direct, exact match of roller bearings for the ball bearings, even at a dedicated bearing supplier .... and I don't think there's any "Made in America" with close enough dimensions
check out these: Inner - MBS #909052R .... Outer - MBS #909001R [or MBS #909067R] ... seal might be National #6064 ... search for roller bearing discussions, these are some of the numbers that have been discussed before here a number of times, the fractional dimensions are not an exact match, but supposedly "they work" .... that said, roller bearings are not an "upgrade", they are a modification that you can hope will work as well as the original roller bearings and that are needed if changing to disc brakes
Bill | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | The roller berings might not be that much of an upgrade. I have burned through 3 sets of them, 3 hubs, and 3 spindles on my 1/2 ton. All in less than 40,000 total miles. I use to get over 80,000 on the ball bearings. I do have disc brakes and 31X10.5 tires on my truck, so maybe its the oversized radials chewing them up. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something else to consider, virtually ALL modern vehicles, with very few exeptions (E series Ford vans come to mind) use ball bearings in the front, and many also have them in the rear on fwds. These have been used pretty much since the mid '80s, I've seen them go 150k+ miles in many cases, and these are sealed non-serviciable bearings. Just think how far the servicable type will go, especially considering advances made in the lubricants.
Bill Burmeister | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I got all new roller bearings in the front of my 46 1/2 ton from chevsofthe40s.com | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Bigbadswingdaddy
Could your installation methods be the cause of your premature wear? How tight are you making the castle nut? What king and how often do you pack your bearings?
Also perhaps the geometry of your disc/spindle setup could be an issue??
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I hand tighten the castle nut while spinning the hub and tapping it with a mallot. When the hub becomes tight to spin, I back the nut off and check for end play. I haven't had a chance to repack the bearings because most have failed within 10,000 miles. Yes, my methods can be flawed.
There is a possibility my spindles and/or hubs were a little worn to begin with. If a race spins in the hub or spindle and goes unnoticed, it could wipe the good part out. I spun a few bearings on the driver side hub. After spinning the 2nd one, I took a good look at the spindle and saw evidence of wear on the spindle. I replaced the axle assembly with another used one. I examined everthing for wear, and used new bearings. 8000 miles later the bearings were worn, one hub was destroyed, and both inner bearings had spun on the spindles. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | daddy - as I pointed out above, the roller assemblies are not an exact match on dimensions: inner roller = bore:32.550mm/outer d.:72.260mm/outer race width:19.00mm inner ball = bore: 31.760mm/ outer d.: 65.1256mm/ width: 19.2786mm .... add a silly millimeter of wear anyplace and double the mismatch, which is why the parts houses and bearing suppliers can't give us a cross reference, there is no direct replacement - someone went to a lot of trouble to find the closest match they could because they wanted to sell something .... maybe if you had a good mic to check all the pieces you could use some shim stock someplace
additionally, re your big tires, a buddy of mine has wider rims and fatter radials on his 55 with the stock bearings and brakes - he's fried bearings and broken spindles because of those tires that exert stress forces the spindle design wasn't engineered for
Bill | | |
