1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 2 New Guy | | New Guy Joined: Jan 2011 Posts: 2 | Looking to find out where to purcahse new lower clamshell retractors or if they cannot be bought what you guys have done to yours to fix them where they will retract. Thanks | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Starting HERE would be a good first start. | | | | | Joined: Jan 2012 Posts: 29 Shop Shark | | Shop Shark Joined: Jan 2012 Posts: 29 | Actually, someone is posting a set for sale on this site.
1948 3100 1948 Fleetline Areo 1951 Suburban Carryall ( http://photobucket.com/51Burb ) 1957 3100 " Tell me who U Hang with & I'll Tell U who You are "!
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I bought mine from rick52 here on stove bolt for my 49. Works great and recommend if he still has some units
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Jun 2008 Posts: 48 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 48 | The original equipment manufacturer is still making them. I just bought one from them a couple of months ago. They can also can rebuild your unit. PM me if you want me to dig out the contact info. | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | I believe it was pplummer who found the og supplier for them.. He listed the company info and posted the part numbers he for them after I had asked him since I needed them also
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | It was his burb build up topic... The info he gave was... http://pullmanmfg.com/standard.html A-105, 9-11lb pull, flat face
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2011 Posts: 2 New Guy | | New Guy Joined: Jan 2011 Posts: 2 | I bought a set off of the Rick guy he is out in CA. I installed them and they work great. It was the last set that he had too. Now I need to find a handle for my lower clamshell door. I am missing the one on the top passenger side of my lower clamshell. Not sure if they are the same or two different pieces as in left and right. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Place an ad in the Swap Meet section. The swap meet has many parts for sale including THESE | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Has anyone bought a replacement set for a TF Suburban? I have a 58 that was originally equipped with barn doors. The retractors and cables aren't there to get the part/model numbers from. Can anyone validate the correct part/model number for the TF Suburbans so I can buy a replacement set from Pullman?
Larry
