8 members (cmayna, Wally / Montana, Shade Baby, Goach2, Donf, dt235sd, Otto Skorzeny, Joe H), 60 guests, and 0 robots.
Topics128,119
Posts1,056,311
Members48,439
Looking to find out where to purcahse new lower clamshell retractors or if they cannot be bought what you guys have done to yours to fix them where they will retract. Thanks
Starting HERE would be a good first start.
Actually, someone is posting a set for sale on this site.
1948 3100
1948 Fleetline Areo
1951 Suburban Carryall ( http://photobucket.com/51Burb )
1957 3100
" Tell me who U Hang with & I'll Tell U who You are "!
I bought mine from rick52 here on stove bolt for my 49. Works great and recommend if he still has some units
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
The original equipment manufacturer is still making them. I just bought one from them a couple of months ago. They can also can rebuild your unit. PM me if you want me to dig out the contact info.
I believe it was pplummer who found the og supplier for them..
He listed the company info and posted the part numbers he for them after I had asked him since I needed them also
It was his burb build up topic...
The info he gave was...
http://pullmanmfg.com/standard.html
A-105, 9-11lb pull, flat face
I bought a set off of the Rick guy he is out in CA. I installed them and they work great. It was the last set that he had too. Now I need to find a handle for my lower clamshell door. I am missing the one on the top passenger side of my lower clamshell. Not sure if they are the same or two different pieces as in left and right.
Place an ad in the Swap Meet section. The swap meet has many parts for sale including THESE
Has anyone bought a replacement set for a TF Suburban? I have a 58 that was originally equipped with barn doors. The retractors and cables aren't there to get the part/model numbers from. Can anyone validate the correct part/model number for the TF Suburbans so I can buy a replacement set from Pullman?
Larry
