7 members (cmayna, dt235sd, baldeagle, 1955 1 Series, NJC, 2 invisible), 93 guests, and 6 robots.
Topics128,016
Posts1,055,337
Members48,419
#87573 11/25/2004 1:09 PM
V
Junior Member
Junior Member
V Offline
First off, the truck is a 1970 C-10 that my son and I are doing a mild restoration on.
The electrical problems;
#1, When I turn the turn signal in either direction, both turn signals flash along with the rear side marker lights.
#2, No rear brake/tail lights.
While removing the bumpers to start body work, I checked the wiring that I could see. No problems found. The problem was going on BEFORE bumper removal. Any suggestions???
Happy Thankgiving and thanks for the help.
"I MUST DO AS THE VOICES IN MY TACKLE BOX COMMAND" >*)))))><{
#87574 11/25/2004 2:08 PM
Almost sounds like you might have a bad ground back there. Is there a light plug for a trailer?
#87575 11/25/2004 2:59 PM
V
Junior Member
Junior Member
V Offline
Big T, Thanks for the reply. Yes there is a trailer light plug. i checked the ground at the point that it was screwed into the bumper. i alos checked for "skined" placs in the wiring going to the plug.
Steve
#87576 11/25/2004 4:19 PM
Riding in the Passing Lane
You might have a short between the marker &
turn lights. Try unpluging the front turn lights
1 at a time at the radiator support & see if that
changes anything. Follow the wire going to the rear lights along the frame. Look for broken or
coroded wires. I,ve got a 70 also. Great truck. smile
1972 Chevy c10 Cheyenne Super
#87577 11/25/2004 5:50 PM
Lights act really funky when they have a bad ground. Ground the lights to the frame and replace or remove the trailer plug and go from there. Good luck and have a great turkey day every one. wink
#87578 11/25/2004 7:58 PM
I think Wrenchbender is an the right track. The turn signals and running lights are two separate circuits. Somehow they have become cross connected.
Check all of those dual filament bulbs. It is surprising how often one filament will break and short to the other filament causing a cross connection.
Gord
1954 1/2 ton 235 4 speed
