1 members (classicchevs),
101
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | fuel filler concealment kit like the one chevsofthe40's sell. I'm wanting to make my own does anyone have this kit if so could you give me the demensions so I could make my own kit. | | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Check the hot rod shops. Many of them sell something you might be able to use. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Are you talking about the kit where it hinges one of the bed wood pieces? If you post a link to the part you're talking about you may get more responses.
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Some folks buy a fuel door from a salvage yard and weld it into place.
A neat idea I saw on a 1970-72ish truck, was they hid the fuel filler behind the side marker reflector on the back of the bed.
as 53moneypit mentioned, check the hot rod sites.
Juliano's hot rod parts
summit racing
speedway motors
the vendors in the links, parts section here on the 'bolt...
-W | | |
