1 members (Gray_Ghost), 79 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#875071 08/15/2012 9:06 PM
I put a small block (283) in my 1951 3600 and I need to mount the accessories to the front of the engine. I want to have the power steering pump, alternator, and the a/c compressor, (Vintage Air) mounted in the front. The Summmit heads have accessory holes that can be used. Does anyone have a picture of their engine showing where they mounted them? I would like to get an idea of where you put them and what brackets you used. Thanks!
Get the brackets that are meant to go with whatever vintage air setup you're using.
My 46 GMC on Photobucket
Have a look at Bills Hotrod Accessories...they have a multitude of brackets for all sorts of setups, including not drilled heads.
1940 Chevy KC 1/2-Ton
dont have air but i used an after market upper and lower from speedway for the alt...and used an alan groves for the power steering pump....everything lines up nice no issues.... here .......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Thanks britcon, I will check them out. Great picture David, thanks. It shows the style of the brackets you used on the alternator, I was hoping to see that. I was starting to try to put the alternator on the right, now I see how to do it on the left.
