| | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 40 New Guy | | New Guy Joined: Aug 2012 Posts: 40 | I made the swap from rock crawlers to hotrods! The new project is a 46'pickup!
Gunna be a long build. got it home in a few pieces and as of 3 days later it's only a frame! Now for the long and unbearable rust control process!
After searching for a year I found the next project! 46' 1/2 ton in pieces! took 2 trips to get it home, but most of the hard work was already done!!! -jerry "Phil" the 46' | | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | Welcome to the site! I am sure you will find a lot of good information here, and I'm sure you will find a few new friends too!
Be sure to post a photo or two of your project and a write up in the gallery!
Randy B. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome lugnutzz, I love the '46 styling. It's easier to dis-assemble than re-assemble, hope you documented things. Good luck with the rest of the journey.
Leo | | | | | Joined: Aug 2012 Posts: 40 New Guy | | New Guy Joined: Aug 2012 Posts: 40 | I'm going to start a build thread once I get some more VP done.... Once I start working, things will slow down a lot... 4 weeks on and 2 off. Still plenty of time to work on it!
I'll try to get some photos up too.
After searching for a year I found the next project! 46' 1/2 ton in pieces! took 2 trips to get it home, but most of the hard work was already done!!! -jerry "Phil" the 46' | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | welcome to the bolt. Lot of good things happens around here....mostly bolters helping bolters. Good luck on your project and remember, we're here to help. | | | | | Joined: Aug 2012 Posts: 40 New Guy | | New Guy Joined: Aug 2012 Posts: 40 | Finely got pics gathered of "phil"
After searching for a year I found the next project! 46' 1/2 ton in pieces! took 2 trips to get it home, but most of the hard work was already done!!! -jerry "Phil" the 46' | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Wow....brings back a few memories ! Looks like you are making good progress on it. | | |
