6 members (Otto Skorzeny, 55shaker, Uncles51, FrankenChevy, mk72, 1 invisible), 83 guests, and 2 robots.
Topics128,022
Posts1,055,387
Members48,422
#874944 08/15/2012 11:09 AM
its raining in new york and i wanted to go for a ride in my truck but the wipers no longer work. i know they worked a few weeks ago before i sent the carb out for a rebuild. the truck runs perfectly but when i turn the knob for the wipers all i get is a hissing sound and a slight increase in idle. how do i trouble shoot this? thank you
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
66flea #874947 08/15/2012 11:40 AM
Start by replacing the rubber hose that runs to the wiper motor. You can possibly check to see if it is a problem by trimming both ends of the existing hose and reconnecting them. However chances are the hose is to old and hard to make a good seal.
Chuck
Hookalatch #874992 08/15/2012 4:11 PM
If you turn the switch and then get a hissing sound, the problem is beyond the hose. I would move the wipers to mid stroke and then start the motor to see if they return to park.
1951 1 Ton Completed
66flea #875120 08/15/2012 11:43 PM
I had the same problem with mine on my 58.Tried all of the do it yourself hints and suggestions new gaskets,transmission fluid and everything else.When all was said and done I still had no wipers , just that hissing noise.Sent it to the wiper man there in New York and they work just as good as new.
6571 #875220 08/16/2012 1:58 PM
Yeah, the Wiperman can fix you right up. I also added the dual action fuel/vacuum pump to my burb. Now I even have wipers when I go up hill.
Kurt
