4 members (55shaker, Cosmo, Gdads51, 1 invisible), 118 guests, and 2 robots.
Topics128,069
Posts1,055,896
Members48,428
#87494 11/12/2001 7:14 PM
Junior Member
Junior Member
Some time back (should have saved it, but didn't) someone had the upgrade to a 12 volt motor to replace the 6 volt blower motor in an AD truck. I have the heater core at the radiator shop to fix a leak, and thought it would be a good time to change and be rid of the resistor since I'll also be doing a complete re-wire. I seem to recall something about a mid 60's VW blower motor which could be adapted? Anybody done this or remember? TIA
#87495 11/12/2001 9:05 PM
Grainger has a 12 volt motor that is easily adaptable. Shaft is the right diameter, the motor is smaller. Can't remember the part number, though. Go to Grainger web page
Fred
52 3600
69 C-10
#87496 11/12/2001 9:25 PM
I gotta Grainger Catalog in front of me and it's a Dayton Motor P/N 2M197 $21.96
12VDC
2350 RPM
1/35 HP
Shaft: 1/4" X 1"
CW or CCW
Overall Length 4-7/8"
Mounts with two studs
Hope this helps. wink
There is no problem so great that it cannot be solved by the application of thought, elbow grease and copious amounts of CASH.
Snappy
#87497 11/14/2001 3:58 AM
Junior Member
Junior Member
Thanks a bunch, Snappy, I just ordered one on line from Grainger. grin
#87498 11/20/2001 9:15 PM
Junior Member
Junior Member
Snappy, thanks so much for the info. Just finished assembly with the new motor and as promised did not have to change holes in the radiator. I used a piece of scrap masonite so the motor would fit flat against its mount in the heater radiator, but other than that, the change out was simply nuts and bolts stuff! Hurray! The only remaining question is whether or not I can use the 6 volt resistor switch which gave it two speeds or if I need to get a 12 volt model of such a device. Do you know? Thought I'd give it a try at the risk of burning up the switch. What do you think?
#87499 11/21/2001 5:48 AM
Anonymous
Unregistered
Anonymous
Unregistered
The switch should work just fine. I remember when I swapped mine out, I was working at a motorhome dealership and I got a motor out of a **** van chassis heater that was physically identical only 12V. The two speed switch under the dash worked perfect for it. smile
#87500 11/04/2006 11:58 AM
Oldbones, your probably gone by now, but maybe someone else can tell me. Grainger here, (Aurora, IL) will only sell to you if you have a commercial account with them or a tax number. NO retail sales. The rest of you ever run into this with them???
Denny Graham
Sanddwich, IL
Denny G
Sandwich, IL
#87501 11/06/2006 3:27 PM
They just wanted the money. Do they want you to pay first? But here we have a walkin store. But i didn't have problems telephone order. Look for a electric motor service, they can hook you up also.
"It ain't a truck if you can't hose out the cab."
#87502 11/06/2006 8:19 PM
Anonymous
Unregistered
Anonymous
Unregistered
Quote
Denny Graham
Sanddwich, IL
Yes, ours here is the same way. I asked them about it and they said it is because they are technically a wholesale outfit, not retail. Must have something to do with the tax laws I suppose.
#87503 11/07/2006 3:05 PM
can't you buy the 12v motors through some of the regular vendors? I think I have seen them listed.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#87504 11/07/2006 3:21 PM
