7 members (Gdads51, Ponchogl, Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, 1 invisible),
90
Mod | | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 13 Member | | Member Joined: Dec 2001 Posts: 13 | any one put tapered roller bearings in a front axle on a 3/4 ton?using the original front hubs? any advice on which kind of bearing work the best.and do you need special races any one have any info thanx | | | | | Joined: Aug 2001 Posts: 3,590 Moderator | | Moderator Joined: Aug 2001 Posts: 3,590 | I put new front bearings in my 6400 this fall that had the barrel shaped bearings. The best parts man in this area side that tapered was the way to go.Had to replace both the races and bearings.They went to gether just fine and adjusted and spun normal.A good parts man can get you the same dem. tapered bearings. DON 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | There was a pretty good posting on this subject a while ago. I think a Timken Bearing fellow said "why change them?" He gave reasons for keeping the ball bearings (run cooler, etc.). I've driven my '48 3/4T daily for 9 1/2 years on the ball bearings (max. 45 MPH, though). Of course, if they got completely trashed, I'd consider going to rollers if they were cheaper. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Aug 2001 Posts: 3,590 Moderator | | Moderator Joined: Aug 2001 Posts: 3,590 | Wally There's a differance between ball bearings, tapered roller bearings,and barrel shaped bearings. I've never seen ball bearings on a spindle before. Am I missing something in my life? I went with tapered roller bearings because every car/truck/trailer I've worked on has always had tapered bearings until this "50" 2-Ton. There must be a reason.
fittyfive Unless your a diehard keep it original fan, I'd go with the tapered roller bearings.
DON 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | When I rebuilt the front end on my '51 GMC 2 ton, I had to replace one of the bearings. Timken no longer produces "tapered" or barrel shaped roller bearings. I had to order a "retrofit" to a tapered bearing and it cost almost $300 (from Timken) and that was for the small bearing. I was unable to obtain grease seals, so I had to re-use them. Anyone know of a source? I need to re-pack them soon, it has been almost 4 years and 3k miles!
*** GMC ***
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | fiftyfive and 2-Ton, I'm one of the slowest ones in these forums and I'm doing less work on my '48 3/4T than practically anybody, but I've got ball bearings up front. They sell ball bearing replacements and show pictures at http://www.americanclassic.com/. There are also roller bearing/race conversions for a bit cheaper. Are we talking about the same thing? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Wally, the ball bearing replacements are readily available, as well as the grease seals for 1 ton and lower models. The heavier trucks got the "barrel" type tapered roller bearings  .
*** GMC ***
| | | | | Joined: Aug 2001 Posts: 3,590 Moderator | | Moderator Joined: Aug 2001 Posts: 3,590 | I've never seen or heard of roller bearings on front spindles before. Thats why this site is so good,there's not a single time I've been here and have not learned at least something. Thanks for the info. DON 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | |
